It is expected as you are using a self-signed certificate. You have to import the cert.pem file in your os or browser if you want to remove this warning.
For the mobile application: Passbolt Help | How to import SSL certificate on mobile application
I would like to thank u so much for your support.
Now application running without any warning.
I can Ignore those errors as I’m using self sign cert ?
[/quote]
You are welcome, ensure you have a proper backup strategy and you are able to restore passbolt in case your server goes down.
Yes, this check works only when you are using a public certificate.
I will foloow the instructions on the below link
