after I installed the passbolt on almalinux and i followed the steps on the installation guide
but after the installation finished i open the webpage it asking to add the email to activate my account after added the same email that i used during installation i can’t receive any email
any suggestion for troubleshooting this issue.
Hello @amr.salem , welcome to our community ![]()
I’d like to know which page are you referencing here? Have you been redirected after the installation to proceed to the account configuration? Or have you manually navigated to your fullBaseUrl after the install was complete?
To summurize, have you already configured the account and being able to log in already or not?
After finishing the configuration of database it’s take long time to GPG key so i reload the page it’s open on webpage asking to add my email i added and showing sent email to activate my account but i can’t recive any email even junk no thing
I manually install the extension but showing connecting but not connect
Alright, it looks like a recent similar issues. Could you take a look at this post ? You should be able to setup your administrator account following this.
I saw this post but how i will run this command on Almalinux
SELECT email, subject, template_vars FROM email_queue ORDER BY id ASC LIMIT 3;
So, through the passbolt-ce-server package installer, you created mysql credentials.
We need these credentials to connect to the database, from the server, you’ll have to run:
mysql -u <YOUR_DB_USER> -p <YOUR_DATABASE>
You will be prompted to enter your password, then run the query.
I got this result
Empty set (0.000 sec)
You confirm that you’ve navigated to the fullBaseUrl as shown in the screenshot from the other post, entered your email and receiving a message that confirm the server sent something?
If yes and you still have empty rows, please share the output of these queries:
SELECT * FROM users;
SELECT * FROM email_queue;
I’m using ip address of server to access and it’s open the email page as showed in screenshoot
output
MariaDB [wfs]> SELECT * FROM users;
| id | role_id | username | active | deleted | created | modified |
| 41cedebc-7d64-4063-8975-eb3bf3365999 | b9888223-5771-40b5-b9c8-b47bdc55dede | IT-Dept@wasata.qa | 0 | 0 | 2023-07-27 06:37:04 | 2023-07-27 06:37:04 |
MariaDB [wfs]> SELECT * FROM email_queue;
I run this query as it is without changing email or other syntax
this is the full URL im using
http://x.x.x.x/auth/login?redirect=%2F&locale=en-UK
I didn’t install any ssl Cert during installation i select none
While following the installation guide, have you installed Haveged to speed up the entropy generation?
Since you are using AlmaLinux, it could also be a SELinux issues, please run these commands:
setsebool -P httpd_use_gpg=on
setsebool -P gpg_web_anon_write=on
semanage permissive -a gpg_web_t
In the meantime, you could create an user with the CLI, meaning you’ll get a generated setup link for a new user.
sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt register_user -i" nginx
Hi Antony
Thank you so much for your support now the system i sup and running i can login to system
but i have one more issue related to ssl cert during installation i chose none ssl
is there any way to install certificate after finishing installation without effect the system ?
I’m using local FQDN for server
You can re-execute the passbolt-configure script. Say no to database and reply to nginx and ssl questions.
I followed the document but when i chose to add ssl manual and added the path on the document.
it’s asking to add valid path.
i tried with auto but it’s failed also as it’s required public domain name.
I run health check and the output as below
[PASS] PHP version 8.1.21.
[PASS] Full base url is set to http://srv-passbolt.wasata.local
[HELP] cURL Error (6) Could not resolve host: srv-passbolt.wasata.local
[PASS] 32 tables found
[PASS] Using latest passbolt version (4.1.2).
[HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
SMTP Settings
[FAIL] 5 error(s) found. Hang in there!
It is written in the document:
you will be prompted for the full path of your certificates
As you are using srv-passbolt.wasata.local as domain name, you have to generate your own certificates for this domain and upload them on your server.
In the documentation, /path/to/certs/cert.pem is an example and must be replaced with the real path of the certificates.
it’s clear but as I’m not expert in Linux can you give me more explanation.
how to generate self-sign certificate and how to know the full path of generated certificate.
Sure, on your server, you can execute this command:
openssl req -x509 \
-newkey rsa:4096 \
-days 3650 \
-subj "/C=LU/ST=Luxembourg/L=Esch-Sur-Alzette/O=Passbolt SA/OU=Passbolt IT Team/CN=srv-passbolt.wasata.local/" \
-nodes \
-addext "subjectAltName = DNS:srv-passbolt.wasata.local" \
-keyout /tmp/key.pem \
-out /tmp/cert.pem
It will generate a key and a cert :
- /tmp/key.pem
- /tmp/cert.pem
You can use these paths.
I’m really apricated your variable support.
I did the same as mentioned and I generated certificate I can now access via https
But still showing in the health check this error
and I got warning when I’m access the website.
