Flashing popup when viewing passwords
Hi, I’m running a fresh install of a self hosted passbolt docker environment. Everything seems to be working, but when I try and view or copy a password I get a flash which might be a popup appearing then instantly disappearing.
It correctly shows or copies the password, but I don’t understand what the flashing is for.
Is is possible to disable this completely?
Thanks
Your computer is too fast :stuck_out_tongue_winking_eye: this popup is the decryption popup :slightly_smiling_face:
