Hey All,
I leverage Duo Federal for MFA and wanted it integrated into Passbolt. I saw that the api was set to only allow duosecurity, yet I’m restricted to duofederal. Here’s what I did to get it fully functional (specific items were removed for obvious reasons).
I’m using a Rocky 9 VM and running Passbolt directly.
Modified Passbolt’s Duo API hostname validation
File:
/usr/share/php/passbolt/plugins/PassboltCe/MultiFactorAuthentication/src/Service/MfaOrgSettings/MfaOrgSettingsDuoService.php
Code:
if (!Validation::custom($hostname, '/^api-[a-fA-F0-9]{8,16}\.duosecurity\.com$/')) {
Made it:
if (!Validation::custom($hostname, '/^api-[a-fA-F0-9]{8,16}\.(duosecurity\.com|duofederal\.com)$/')) {
Content Security Policy Change
File:
/usr/share/php/passbolt/src/Middleware/ContentSecurityPolicyMiddleware.php
Code:
"form-action 'self' https://*.duosecurity.com",
Rather than modifying the Passbolt source middleware, I overrode the CSP in:
File:
/etc/passbolt/passbolt.php
Added:
'security' => [
'csp' => "default-src 'none'; script-src 'self'; style-src 'self'; img-src 'self'; font-src 'self'; connect-src 'self'; base-uri 'self'; frame-src 'self'; frame-ancestors 'none'; form-action 'self' https://*.duosecurity.com https://*.duofederal.com",
Original:
return [
‘App’ => [
‘fullBaseUrl’ => ‘https://.com’
// Database configuration.
‘Datasources’ => [
‘default’ => [
‘driver’ => ‘Cake\Database\Driver\Mysql’,
‘host’ => ‘localhost’,
‘port’ => ‘’,
‘username’ => ‘root’,
‘password’ => ‘’,
‘database’ => ‘’,
‘passbolt’ => [
// GPG Configuration.
// The keyring must be owned and accessible by the webserver user.
‘gpg’ => [
// Main server key.
‘serverKey’ => [
‘fingerprint’ => ‘’,
‘public’ => CONFIG . DS . ‘gpg’ . DS . ‘serverkey.asc’,
‘private’ => CONFIG . DS . ‘gpg’ . DS . ‘serverkey_private.asc’,
‘ssl’ => [
‘force’ => true,
New:
return [
‘App’ => [
‘fullBaseUrl’ => ‘https://.com’,
‘Datasources’ => [
‘default’ => [
‘port’ => ‘’,
‘password’ => ‘’,
‘database’ => ‘’,
‘passbolt’ => [
‘gpg’ => [
// Main server key.
‘serverKey’ => [
‘ssl’ => [
‘force’ => true,
‘security’ => [
‘csp’ => “default-src ‘none’; script-src ‘self’; style-src ‘self’; img-src ‘self’; font-src ‘self’; connect-src ‘self’; base-uri ‘self’; frame-src ‘self’; frame-ancestors ‘none’; form-action ‘self’ https://.duosecurity.com https://.duofederal.com”,
This was found by inspecting the network traffic and seeing this in the console:
Sending form data to ‘https://us–…/mfa/verify/duo/prompt’
violates the following Content Security Policy directive:
“form-action ‘self’ https://*.duosecurity.com”.
Set Environmental Variables for Duo Config
Modified the php-fpm www pool config file (running nginx) to include the needed environmental variables.
file:
/etc/php-fpm.d/www.conf
Code:
under line 24 - 24 group = nginx
add the below:
env[PASSBOLT_PLUGINS_MFA_PROVIDERS_DUO] = true
env[PASSBOLT_PLUGINS_MFA_DUO_CLIENT_ID] =
env[PASSBOLT_PLUGINS_MFA_DUO_CLIENT_SECRET] =
env[PASSBOLT_PLUGINS_MFA_DUO_API_HOSTNAME] =
