Hello to all the Passbolt comunity,
First of all thanks to all the comunity to let me create this new topic and get all the help possible for solving the issues, i will try to help others in the same way.
Second of all, I`m stuck on the GPG key configuration, I have tried all the things on this community forum, followed any installation instruction, any chatgpt solution, but none of them have help me to solve this error.
My problem es in the GPG Configuration:
[PASS] The public key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The private key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The server key fingerprint matches the one defined in /var/www/passbolt/config/passbolt.php.
[PASS] The server public key defined in the /var/www/passbolt/config/passbolt.php (or environment variables) is in the keyring.
As you can see, i get two FAILs on the private key and the public key that they can not be used to verify a message,
I have tried any command, I have also tried to delete de entire /var/www/.gnupg and created another key with the correct permissions and making the right import and export.
I do not really now what else i can do, i have looked on every way and none of them help me.
Thanks for all the attention and possible help given,
Best regards.
