I am looking to roll this out to about 200 people. Can I import users?
Hi @skione,
Currently passbolt does not have an import user function however you have several options:
- Build yourself a small bash script running server side that creates users using
register_usercommand (see../bin/cake passbolt register_user --help) - Build yourself a small script that connects to the API and user the create user endpoint. See. https://help.passbolt.com/api/users/create
- Synchronize user from LDAP (Passbolt Pro only atm)
Thank you for your response. I’ll likely use the bash method as it seems fastest. I was going to use the API but I think I’ll do this instead. Is there a feature board where I can request this? Seems like being able to import users would be a common feature request.
Yes you can create a new entry in under “backlog” category. It has not been requested yet I think.
Thanks again and wow that is kind of surprising.
