How to reset forgotten passphrase for user ?
How can I send invitation for user to reset passphrase?
You can’t. See. Passbolt Help | How to recover my passphrase?
Unfortunately it is not possible to reset your private key passphrase if you do not remember the original. Similarly if you have lost your private key and you do not have a backup, you cannot decrypt your passwords anymore.
Sadly, you have lost access to the passwords that you have not yet shared. If you have shared your password with somebody you can create a new account and ask them to share your password back with you.
If you can’t remember your passphrase, the best thing to do is to start anew.
I forgot my login passphrase but I have a backup of my Private Key Block. But I can not reset my passphrase through private key block. During reset process, it always asking to contact administrator for reset. Please help me to reset my forgotten passphrase.
Hey @pranab.halder,
Remy’s response above is still for the most part the correct answer here.
If your instance has Account Recovery enabled and you did enroll in that feature the admin of your instance will be able to help you complete the steps, but if this feature wasn’t enabled or you weren’t already enrolled you won’t be able to.
