Hallo,
I used the community edition fo a while, I just updated to Pro and now I’d like to move the already inserted accounts in a folder.
I can create folders and add new accounts bot I don’t know how to move the passwords inside.
Thanks
Hallo,
Thanks
Hi @Spal,
You can select the resource in the password workspace and drag/drop them in the folders on the left.
You can see it in the video here:
OK, I think I have a problem, when I try to drag a password the folders disappear
Hello @Spal,
You might have database integrity issues. Can you run the following command from your passbolt folder in order to fix them if any: su -s /bin/bash -c "./bin/cake passbolt cleanup" www-data
For further support, as pro customer you can contact us directly on support(at)passbolt.com
It worked, Thank you
Daniele
