Hello everyone,
We’ve identified an issue in the Passbolt Browser Extension 5.4.0 affecting the import resources functionality in certain environments.
Summary of the Problem
In version 5.4.0 of the browser extension, the Import resources action is not functioning when End-to-End Encrypted (E2EE) metadata is not enabled.
When attempting to import resources, clicking Create > Import resources results in no action being triggered — nothing happens in the UI.
Who Is Impacted
- Passbolt Cloud: All workspaces are affected.
- Passbolt PRO/CE: Only instances with E2EE metadata disabled are affected.
On-premise instances with E2EE metadata enabled are not affected.
Current Status
Our engineering team is actively investigating the root cause and preparing a fix. We will update this thread as soon as a patch is available.
Workarounds
Currently, there is no direct workaround for Cloud users.
On-premise users can enable E2EE metadata if possible, but we recommend waiting for the official fix.
We apologize for the inconvenience and appreciate your patience while we work on resolving this issue.
