Install Passbolt Pro on CentOS 8
Hi ist there an updated howto to install Passbolt Pro on CentOS 8? Installer for CentOS 7 stops with
Problem: conflicting requests
- nothing provides epel-release = 7 needed by remi-release-7.8-1.el7.remi.noarch
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages
Obviously its for CentOS 7. What is about CentOS 8?
Hi @kingfisher
I haven’t had the time to take a look into giving support for centos8 on the install scripts. If you happen to give it a run on centos 8 you can open an issue with the full output here: https://github.com/passbolt/passbolt_install_scripts or a pull request, of course.
