Colleagues, good afternoon. When installing on debian 12, I get an installation error at the very end:
Creating config file /etc/php/8.2/mods-available/gd.ini with new version
Setting up php-gd (2:8.2+93) ...
Setting up passbolt-ce-server (4.6.2-1) ...
/var/lib/dpkg/info/passbolt-ce-server.postinst: line 159: mysql: command not found
dpkg: error processing package passbolt-ce-server (--configure):
installed passbolt-ce-server package post-installation script subprocess returned error exit status 127
Processing triggers for php8.2-cli (8.2.18-1~deb12u1) ...
Processing triggers for php8.2-fpm (8.2.18-1~deb12u1) ...
Processing triggers for libc-bin (2.36-9+deb12u4) ...
Processing triggers for nginx (1.22.1-9) ...
Triggering nginx reload ...
Errors were encountered while processing:
passbolt-ce-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
Can you tell me what the problem might be?
