thanks for all your responses!
I use the same app version and for the server i run a docker container with latest-ce.
Tried the following already:
docker-compose -f docker-compose-ce.yaml down
docker-compose -f docker-compose-ce.yaml up -d
How can i check which server version is active? And for the health check i wasnt able to run it the only cake i found was at /var/lib/docker/overlay2//342…/merged/usr//php/passbolt/bin/cake, but i wasn’t able to use it.
Had to open the bash first then i was able to execute the healthcheck.
[FAIL] This installation is not up to date. Currently using 4.4.0 and it should be 4.8.0.
I thought when i use latest-ce it should load the newest version after the docker-compose?
Hello @Kanonenfutter, you have to download the image again as the first time you ran docker-compose it downloaded it and now it uses that old image.
To update it just do a docker pull with the image name
Thank you very much it works fine now!
