Issue sending SMTP mails via SES
My passbolt instance is not sending any mails.I’ve checked the settings in the administration panel, all mails are allowed to sent.
Our Passbolt installation runs on Docker, current version. The selected mail provider is Amazon SES.
This is the output from the healthcheck:
 [PASS] PHP version 7.4.33.
 [PASS] Full base url is set to https://passbolt.ilgenfritz.biz
fopen(https://passbolt.ilgenfritz.biz/healthcheck/status.json): failed to open stream: operation failed
 [PASS] 26 tables found
 [PASS] Using latest passbolt version (3.8.3).
 SMTP Settings
And here is the output from the “send_test_email” function:
 Debug email shell
Email configuration
Host: email-smtp.eu-central-1.amazonaws.com
Port: 587
Username: ********* (censored)
Password: *********
TLS: true
Sending email from: Passbolt <noreply@passboltdomain.com>
Sending email to: no-reply@passbolt.com
Trace
[220] email-smtp.amazonaws.com ESMTP SimpleEmailService-d-RFEKVBS9L AD2K3HzwcPSMhCBRCpfx
Error: SMTP server did not accept the connection or trying to connect to non TLS SMTP server using TLS.
Hi @tobi,
could your issue be related to this post resp. be fixed by this?
https://community.passbolt.com/t/smtp-not-working-after-upgrade-to-3-8-1-from-3-7/6089/11?u=pabloelcolombiano
Hi @pabloelcolombiano,
i tried your suggestion.
In our passbolt.php config file the parameter “client” is uncommented.
// Email configuration.
    'EmailTransport' => [
        'default' => [
            'host' => 'email-smtp.eu-central-1.amazonaws.com',
            'port' => 587,
            'username' => 'XXXX',
            'password' => 'XXXX',
            'tls' => true,
            //'timeout' => 30,
            //'client' => null,
            //'url' => null,
We don’t have a “app.php” file. I deleted the database entry as described, but it has no effect. Passbolt still won’t send any mails.
mysql> DELETE FROM organization_settings WHERE property = "smtp";
Query OK, 1 row affected (0.02 sec)
Hello @tobi,
Just for clarification, did the email sending ever worked for you? Like was it working and an update or another operation broke it or you are setting it up and having a hard time to make it work?
Gérold.
Hello @Gerold,
Yes, it was working well for years. I think one of the latest updates broke it, even if we don’t changed anything on our site.
Cheers, Tobi
See my solution:
The problem is the client value being null. Once it is set to the actual IP address, all the servers including Gmail will start accepting your emails. I don’t know why this is hardly mentioned anywhere in the install instructions?!
Note: external article link being removed, solution is as noted here
