Thank you for your response!
When I mentioned the generated password, I was using it as an example of a “complex” one. If I manually create a similar password myself, I encounter the same issues with infinite loading. That is, even using a password like P455w0RD!!! causes the system to get stuck in an endless saving process.
When this issue began, literally nothing had changed—absolutely nothing. It just started on its own.
Additionally, here are my latest observations and information about our server:
The problem was temporarily resolved when I removed individual administrator accounts from the access permissions for all passwords. Initially, since deployment, each technician used a separate account, but now we are all using a single shared account. However, for completely unclear reasons, the issues have reappeared—the server didn’t function properly for even a week. I initially suspected the problem lay in the encryption process: many characters in the password, numerous access rights assigned to a single password entry, and so on. But apparently that’s not the case. Also, our server has approximately 180 users in total, and each user has been manually granted access to their respective password.
Here is the information you requested from me:
contentScripts/js/dist/vendors.js:2 (uu)
contentScripts/js/dist/vendors.js:2 (vu)
contentScripts/js/dist/vendors.js:2 (hu)
contentScripts/js/dist/vendors.js:2 (gu)
contentScripts/js/dist/vendors.js:2 (анонимные функции)
contentScripts/js/dist/vendors.js:2 (ks)
contentScripts/js/dist/vendors.js:2 (us)
contentScripts/js/dist/vendors.js:2 (Ba)
contentScripts/js/dist/vendors.js:2 (ts)
contentScripts/js/dist/vendors.js:2 (enqueueSetState)
contentScripts/js/dist/vendors.js:2 (v.setState)
contentScripts/js/dist/app.js:2 (getUserSettings)
Unchecked runtime.lastError: The page keeping the extension port is moved into back/forward cache, so the message channel is closed.
Potential permissions policy violation: clipboard-write is not allowed in this document.
Error: The url does not match the pattern.
Error: Cannot parse setup url. The url does not match the pattern.
Error: Cannot parse account recovery url. The url does not match the pattern.
