Hi, while using the helm package of passbolt, not setting the GPG public and private key will start the job-create-gpg job at startup to create the key.
When doing so the GPG Fingerprint is not set inside the passbolt container and the application fails.
Setting manually the PASSBOLT_GPG_SERVER_KEY_FINGERPRINT env variable inside the container works, but this should be done automatically when the job runs, what am I doing wrong ?
// _,///./_//__/
Healthcheck shell…2025-02-11 09:21:31 error: [Cake\Core\Exception\CakeException] Could not use key for signing. get_key failed in
/usr/share/php/passbolt/src/Utility/OpenPGP/Backends/Gnupg.php on line 240
Stack Trace:
- /usr/share/php/passbolt/src/Service/Healthcheck/Gpg/CanSignGpgHealthcheck.php:51
- /usr/share/php/passbolt/src/Command/HealthcheckCommand.php:183
- /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php:190
- /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php:334
- /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php:172
- /usr/share/php/passbolt/bin/cake.php:13
- [main]:
Caused by: [Exception] get_key failed in /usr/share/php/passbolt/src/Utility/OpenPGP/Backends/Gnupg.php on line 236
Stack Trace:
- /usr/share/php/passbolt/src/Utility/OpenPGP/Backends/Gnupg.php:236
- [main]:
2025-02-11 09:21:31 error: [Cake\Core\Exception\CakeException] Could not use key for signing. get_key failed in /usr/share/php/passbolt/src/Utility/OpenPGP/Backends/G
Stack Trace:
- [main]:
Stack Trace:
- [main]:
