JWT authentication issues with API
Now that the previous authentication method is labeled as legacy we were looking at updating our services to login with the new JWT method. But i’m walking into issues and can’t seem to authenticate using JWT in NodeJS. Note that we can authenticate using openPGPkeys using the /auth/verify.json and auth/login.json paths.
I got the user_id for the post request to /auth/jwt/login.json from the users page inside passbolt, after clicking on the user and copying the id from the url.
The following is a concept of how we sign and encrypt the data:
const json = {
  version: "1.0.0",
  domain: "https://some.domain.local",
  verify_token: crypto.randomUUID(),
  verify_token_expiry: (Date.now() + (2*60*1000) / 1000)
const passphrase = "";
let clientPublicKeyArmored = fs.readFileSync('./public.client', {
  encoding: 'utf8'
let clientPrivateKeyArmored = fs.readFileSync('./private.client', {
  encoding: 'utf8'
let serverPublicKeyArmored = fs.readFileSync('./public.server', {
  encoding: 'utf8',
  flag: 'r'
}); // This is the public key we get from /auth/verify.json, saved for convenience
serverPublicKeyArmored = JSON.parse(serverPublicKeyArmored); // Parse the inline formatting back to a full text string
const serverPublicKey = await openpgp.readKey({ armoredKey: serverPublicKeyArmored });
const clientPublicKey = await openpgp.readKey({ armoredKey: clientPublicKeyArmored });
const clientPrivateKey = await openpgp.decryptKey({
    privateKey: await openpgp.readPrivateKey({ armoredKey: clientPrivateKeyArmored }),
    passphrase
let encrypted = await openpgp.encrypt({
      message: await openpgp.createMessage({ text: JSON.stringify(json), format: 'utf8' }),
      encryptionKeys: serverPublicKey,
      signingKeys: clientPrivateKey,
encrypted = encrypted.replace(/\n/g, '\\n'); // Inline formatting
console.log(encrypted)
As you can see this prints the signed and encrypted PGP message block. Because of URL formatting i’ve added \n for newlines so the whole message is inline formatted and can be send through curl/postman. I’ve even botched up a POC where i post a body to /auth/jwt/login.json, yet to no avail.
body example:
    "user_id": "a3f4ace8-88da-40db-91d9-5aea4ef3ca57",
    "challenge": "-----BEGIN PGP MESSAGE-----\n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\nyavrks0CyPurYJItzdp19t83CuqM\n=SnsW\n-----END PGP MESSAGE-----\n"
The only result i ever see is:
    "header": {
        "id": "e92fe22e-4910-478d-ac48-741464087a23",
        "status": "error",
        "servertime": 1728295676,
        "action": "28c0972b-e6a2-5d44-a5cb-bc2d11799cc1",
        "message": "The credentials are invalid.",
        "url": "/auth/jwt/login.json",
        "code": 400
    "body": ""
Any help is very much appreciated.
Health check has fully passed without errors:
 [PASS] PHP version 8.2.20.
 [PASS] Full base url is set to https://domain
 [HELP] cURL Error (60) SSL certificate problem: self-signed certificate in certificate chain
 SMTP settings
 [WARN] The SMTP Settings source is: /etc/passbolt/passbolt.php.
 [INFO] The self registration provider is: Email domain safe list.
 [WARN] The deprecated self registration public setting was found in /etc/passbolt/passbolt.php.
 [HELP] You may remove the "passbolt.registration.public" setting.
 [PASS] 31 tables found.
Do you have any additional information in the server logs? You should get some more information on what check is failing. I can try to reproduce later with your code, but that might be quicker checking that first.
Thank you for your reply.
I run passbolt in a docker container. Where the /var/log/passbolt/error.log streams into /dev/stderr. error.log → /dev/stderr
docker logs gives:
[07/Oct/2024:15:50:33 +0200] "POST /auth/jwt/login.json HTTP/1.1" 400 250 "-" "PostmanRuntime/7.42.0"
2024-10-07 15:50:33,032 INFO reaped unknown pid 10762 (exit status 0)
2024-10-07 15:50:33,032 INFO reaped unknown pid 10764 (exit status 0)
2024-10-07 15:50:33,032 INFO reaped unknown pid 10767 (exit status 0)
2024-10-07 15:50:33,032 INFO reaped unknown pid 10769 (exit status 0)
2024-10-07 15:50:33,032 INFO reaped unknown pid 10772 (exit status 0)
2024-10-07 15:50:33,032 INFO reaped unknown pid 10774 (exit status 0)
2024-10-07 15:50:33,033 INFO reaped unknown pid 10776 (exit status 0)
2024-10-07 15:50:33,033 INFO reaped unknown pid 10778 (exit status 0)
Besides code 400 this doesn’t explain to me which check is failing.
These are the nginx log not passbolt log.
I will give it a shot.
I think that’s your issue, should be
This worked for me
const openpgp = require('openpgp');
const fs = require('fs');
const fetch = require('node-fetch');
process.env.NODE_TLS_REJECT_UNAUTHORIZED = "0";
const domain = 'https://localhost';
(async () => {
    const json = {
        version: "1.0.0",
        domain: domain,
        verify_token_expiry: ((Date.now() + (2*60*1000)) / 1000)
    const passphrase = "ada@passbolt.com";
    const clientPrivateKeyArmored = fs.readFileSync('./private.client', {encoding: 'utf8',});
        privateKey: await openpgp.readPrivateKey({armoredKey: clientPrivateKeyArmored}),
        passphrase
    const serverPublicKeyArmored = fs.readFileSync('./public.server', {encoding: 'utf8',});
    const serverPublicKey = await openpgp.readKey({armoredKey: serverPublicKeyArmored});
        message: await openpgp.createMessage({text: JSON.stringify(json)}),
    const response = await fetch(domain + '/auth/jwt/login.json', {
        method: "POST",
        headers: {
            "Content-Type": "application/json",
        body: JSON.stringify({
            "user_id": "f848277c-5398-58f8-a82a-72397af2d450",
            "challenge": encrypted
    const body = await response.text();
    console.log(body);
Thank you very much for looking into this.
Silly me.
Regardless of anything, it works. I’m pretty sure i used a correct epoch before, but i guess not.
Thank you.
My actual issue was that the verify_token_expiry can only last for 1 hour. And then later when i botched that equation. Thanks once again though.
