Hey guys! So I’m trying to sign and encrypt the payload using a flask app.py running terminal commands. I’m able to sign it using the user’s private key and encrypt it with the server’s public key but when sending the post webhook to /auth/jwt/login.json I just get the “The credentials are invalid” error.
Here’s my code:
import subprocess
import uuid
import json
from datetime import datetime, timedelta
from flask import Flask, Response, request, jsonify
app = Flask(__name__)
domain = 'https://sample.domain.com'
userUUID = '040b4777-48a8-4d3f-b724-c8r548457024'
@app.route("/")
def sign_message():
try:
# Import the public key before signing
#import_pubkey()
# Prepare the JSON payload to sign
input_message = {
"version": "1.0.5",
"domain": domain,
"verify_token": str(uuid.uuid4()),
"verify_token_expiry": (datetime.now() + timedelta(seconds=60 * 60)).strftime('%s')
input_message_str = json.dumps(input_message, indent=4) # Serialize to JSON string
print(input_message_str)
# Command to sign the message
command = [
"gpg", "--pinentry-mode", "loopback", "--batch", "--yes",
"--passphrase", "[privateKeyPassphrase]", "--sign", "--armor"
subcommand = [
"gpg", "--encrypt", "--armor", "--recipient", "1232312[publickeyfingerprint]"
# Run the GPG command and capture the signed output
signed = subprocess.run(command, text=True, input=input_message_str, capture_output=True, check=True)
# Get the signed message
signed_output = signed.stdout
#run the gpg command for encryption
encrypted = subprocess.run(subcommand, text=True, input=signed_output, capture_output=True, check=True)
#get the encrypted output
encrypted_output = encrypted.stdout
#format both data
response_data = {"encrypted_output": encrypted_output}
# Return the encrypted output as plain text (non-escaped)
return jsonify(response_data)
except subprocess.CalledProcessError as e:
# Return error details in JSON format
return Response(f'{{"error": "Command failed.", "details": "{e.stderr}"}}', mimetype="application/json", status=500)
if __name__ == "__main__":
app.run(host="0.0.0.0", port=5000, debug=True)
I then copy the “encrypted_output” showing on my browser to make.com’s HTTP make a request module to send a post command to https://sample.domain.com/auth/jwt/login.json. It then gives me the credentials invalid error.
I’m able to decrypt and verify the encrypted payload within the terminal so I’m scratching my head on what I’m missing here.
here’s what I’m sending out via make.com
{"user_id":"040b4777-48a8-4d3f-b724-c8r548457024","challenge":"-----BEGIN PGP MESSAGE-----\n\nhQGMAyeBZQ98+. . . . .."}
Here’s passbolt healthcheck
[INFO] Linux 8f88c8290c3e 6.8.0-45-generic #45-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 30 12:02:04 UTC 2024 x86_64 GNU/Linux
[PASS] PHP version 8.2.24.
[HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://vps.useworkhero.com
SMTP settings
[PASS] Using latest passbolt version (4.10.1).
[PASS] 34 tables found.
Anything helps! Thanky you!
