Hi, i have a problem with my helm deploy.
this is the healthcheck
[INFO] Linux passbolt-depl-srv-554495b87b-2xjvv 6.8.0-78-generic #78-Ubuntu SMP PREEMPT_DYNAMIC Tue Aug 12 11:34:18 UTC 2025 x86_64 GNU/Linux
[PASS] PHP version 8.2.29.
[HELP] See timedatectl | grep -i -A 1 clock. More information:
[PASS] Full base url is set to https://vault.prod.kube.a1.local
SMTP settings
[FAIL] The server key fingerprint doesn’t match the one defined in /etc/passbolt/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /var/lib/passbolt/.gnupg” www-data | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt/gpg/serverkey_private.asc” www-data
[PASS] Using latest passbolt version (5.4.1).
[PASS] 34 tables found.
Metadata
[FAIL] 8 error(s) found. Hang in there!
[FAIL] The server key does not have a valid email id. –> why this message, i have set the email id ?
my helm value file
APP_FULL_BASE_URL: "https://vault.prod.kube.test.local"
PASSBOLT_KEY-EMAIL: "test@test.com"
DATASOURCES_DEFAULT_USERNAME: "postgres"
DATASOURCES_DEFAULT_PASSWORD: "passbolt"
plain:
DATASOURCES_DEFAULT_HOST: “passbolt-postgres-svc.authentification.svc.cluster.local”
DATASOURCES_DEFAULT_PORT: “5432”
##EMAIL##
EMAIL_TRANSPORT_DEFAULT_HOST: x.x.x.x
EMAIL_TRANSPORT_DEFAULT_PORT: 25
EMAIL_DEFAULT_FROM: “test@test.com”
EMAIL_DEFAULT_FROM_NAME: “Passbolt”
persistence:
enabled: true
existingClaim: passbolt-app-pvc
storageClass: “nfs-csi”
accessModes:
- ReadWriteMany
service:
type: ClusterIP
annotations: {}
http:
port: 80
targetPort: 80
