Login not working when using new Device/other IP
Hey,
i have set up a Passbolt Server on a Ubuntu Server VM behind an BunkerWEB WAF.
When i access the site from my Laptop using its VPN (Static IP) i can easily log in to my account.
When i use any other device or disable my VPN it wants me to reset my user account?
When i turn my VPN back on i can again log in just fine.
It also asks for a GPG Key to reset my authentication but i cant find out where i am supposed to get that key?
Thanks
G’day Chrweiss.
The reason it’s doing that is because the fullBaseUrl has changed.
If your fullBaseUrl is https://passbolt.example.com
and you change any of the URL
  • https > http
  • different domain (i.e. you don’t need the subdomain https://example.com)
  • Or if you need a port number at the end without VPN https://passbolt.example.com:8080
If any of the the elements of the URL changes then the passbolt browser extension fails the check and prompts for setting up a new user.
Let me know if you have any questions.
Cheers
Gareth
