Login through Quick Access works after renewed server's gpg key
After renewing the expired server’s gpg key I couldn’t login through the web.
I’ve read that it was related to the extension and that I had to recover my account.
BUT If I use the “quick access” I can effectively log in!!!
Would it be possible to be able to login also through the web without having to recover the account?
Thanks!
Hi @iaf welcome to the forum!
What versions are you using?
Lower right corner of served passbolt page, hover over heart icon:
Hi!
The version is 2.12.0 for both server and extension.
Thanks
Hello iaf,
i have also a problem with an expired gpg key.
Can you tell me how to renew them?
Hi!
You will have to renew your gpg key.
It would be something like this:
# Get the key id
gpg --homedir /path_to_passbolt_gpg_config --list-keys
# key-id from the previous step
gpg --homedir /path_to_passbolt_gpg_config --edit-key key-id
# Renew key
> expire
# a year, for example
> 365
# Select subkey
> key 1
> expire
> 365
Sorry if this is not completely accurate. I don’t have the commands in front of me right now.
But maybe this can guide you.
