Metadata private key not found after Upgrading to Passbolt 5.6.1
I updated my Passbolt (CE) to v5.6.1 and after enabling Zero-knowledge mode and Rotate key, I run a Healthcheck and it showing the following error:
Metadata
[FAIL] No server metadata private key found.
[FAIL] No active metadata key found.
This problem only started after the update and enabling Zero-knowledge mode.
Any help or guidance on how to fix this would be really appreciated.
Hello, there is post about your problem: https://community.passbolt.com/t/metadata-private-key-error-after-upgrading-to-passbolt-5-x-healthcheck-fails/12974/5
My passbolt instance is now working correctly! You are welcome.
