Hi. I just tried to upgrade to 4.5 and got the following error:
using migration paths
- /etc/passbolt/Migrations
using seed paths
using environment default
using adapter mysql
using database passboltdb
ordering by creation time
== 20230607174300 V410AddRbacsTables: migrating
PDOException: SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘rbacs’ already exists in /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php:192
Stack trace:
#0 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php(192): PDO->exec()
#1 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/MysqlAdapter.php(358): Phinx\Db\Adapter\PdoAdapter->execute()
#2 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/AdapterWrapper.php(349): Phinx\Db\Adapter\MysqlAdapter->createTable()
#3 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/TimedOutputAdapter.php(113): Phinx\Db\Adapter\AdapterWrapper->createTable()
#4 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/AdapterWrapper.php(349): Phinx\Db\Adapter\TimedOutputAdapter->createTable()
#5 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Plan/Plan.php(146): Phinx\Db\Adapter\AdapterWrapper->createTable()
#6 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Table.php(719): Phinx\Db\Plan\Plan->execute()
#7 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Table.php(615): Phinx\Db\Table->executeActions()
#8 /usr/share/php/passbolt/vendor/cakephp/migrations/src/Table.php(138): Phinx\Db\Table->create()
#9 /etc/passbolt/Migrations/20230607174300_V410AddRbacsTables.php(89): Migrations\Table->create()
#10 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager/Environment.php(111): V410AddRbacsTables->up()
#11 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager.php(388): Phinx\Migration\Manager\Environment->executeMigration()
#12 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager.php(359): Phinx\Migration\Manager->executeMigration()
#13 /usr/share/php/passbolt/vendor/robmorgan/phinx/src/Phinx/Console/Command/Migrate.php(122): Phinx\Migration\Manager->migrate()
#14 /usr/share/php/passbolt/vendor/cakephp/migrations/src/Command/Phinx/CommandTrait.php(37): Phinx\Console\Command\Migrate->execute()
#15 /usr/share/php/passbolt/vendor/cakephp/migrations/src/Command/Phinx/Migrate.php(85): Migrations\Command\Phinx\Migrate->parentExecute()
#16 /usr/share/php/passbolt/vendor/symfony/console/Command/Command.php(298): Migrations\Command\Phinx\Migrate->execute()
#17 /usr/share/php/passbolt/vendor/symfony/console/Application.php(1040): Symfony\Component\Console\Command\Command->run()
#18 /usr/share/php/passbolt/vendor/symfony/console/Application.php(301): Symfony\Component\Console\Application->doRunCommand()
#19 /usr/share/php/passbolt/vendor/symfony/console/Application.php(171): Symfony\Component\Console\Application->doRun()
#20 /usr/share/php/passbolt/vendor/cakephp/migrations/src/Command/MigrationsCommand.php(126): Symfony\Component\Console\Application->run()
#21 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(189): Migrations\Command\MigrationsCommand->execute()
#22 /usr/share/php/passbolt/vendor/cakephp/migrations/src/Command/MigrationsCommand.php(198): Cake\Console\BaseCommand->run()
#23 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(282): Migrations\Command\MigrationsCommand->run()
#24 /usr/share/php/passbolt/src/Command/DatabaseAwareCommandTrait.php(62): Cake\Console\BaseCommand->executeCommand()
#25 /usr/share/php/passbolt/src/Command/MigrateCommand.php(80): App\Command\MigrateCommand->runMigrationsMigrateCommand()
#26 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(189): App\Command\MigrateCommand->execute()
#27 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php(334): Cake\Console\BaseCommand->run()
#28 /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php(172): Cake\Console\CommandRunner->runCommand()
#29 /usr/share/php/passbolt/bin/cake.php(13): Cake\Console\CommandRunner->run()
#30 {main}
dpkg: Fehler beim Bearbeiten des Paketes passbolt-pro-server (–configure):
How can I fix it?
Thanks!
EDIT: error.log shows some msgs like this: 2024-02-14 07:19:25 error: [PDOException] SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘Users.disabled’ in ‘where clause’ in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
Request URL: /resources/a235d07e-6e24-4f00-ac20-b29f52efec88.json?api-version=v2&contain%5Bpermission%5D=1&contain%5Bfavorite%5D=1&contain%5Btag%5D=1
