it is possible to set a minimum entropy of the passphrase of 50 bits in the community edition… I would need to raise it… it would be interesting because the community would be an optimal solution for my company… but as I was saying, I would only like to definitively set a value other than 50 bits of entropy without obviously necessarily having the advantages of the pro version plugin which allows you to do it from the interface… thanks!
