hello
passbolt docker version
image: passbolt/passbolt:5.9.0-1-ce
Device: Google Pixel 8 Pro
Android 16 (36)
Passbolt 2.7.1-48
21:22:23 [Session] Passphrase cache cleared
21:22:23 [Session] Passphrase cached
21:22:23 Getting server pgp and rsa keys
21:22:24 → GET https://pass.*.*/auth/verify.json h2
21:22:24 ← 200 https://pass.*.*/auth/verify.json (106ms, unknown-length body)
21:22:24 → GET https://pass.*.*/auth/jwt/rsa.json h2
21:22:24 ← 200 https://pass.*.*/auth/jwt/rsa.json (74ms, unknown-length body)
21:22:24 Getting server pgp and rsa keys succeeded
21:22:24 Checking if time adjustment is needed
21:22:24 Local time sync needed. Adjusted: -2
21:22:24 Verifying server fingerprint
21:22:24 Server key fingerprint is valid
21:22:24 Preparing sign in challenge
21:22:25 There was an error during encryptSignMessageArmored
go.Universe$proxyerror: gopenpgp: the key contains too many entities
at com.proton.gopenpgp.crypto.Crypto.newKeyFromArmored(Native Method)
at com.passbolt.mobile.android.gopenpgp.OpenPgp$encryptSignMessageArmored$2.invokeSuspend(SourceFile:63)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(SourceFile:34)
at kotlinx.coroutines.DispatchedTask.run(SourceFile:100)
at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(SourceFile:124)
at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:89)
at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(SourceFile:586)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(SourceFile:820)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(SourceFile:717)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:704)
21:22:25 Error during preparing challenge - incorrect passphrase
21:22:32 [Session] Passphrase cache cleared
21:22:32 [Session] Passphrase cached
21:22:32 Getting server pgp and rsa keys
21:22:32 → GET https://pass.*.*/auth/verify.json h2
21:22:32 ← 200 https://pass.*.*/auth/verify.json (150ms, unknown-length body)
21:22:32 → GET https://pass.*.*/auth/jwt/rsa.json h2
21:22:33 ← 200 https://pass.*.*/auth/jwt/rsa.json (81ms, unknown-length body)
21:22:33 Getting server pgp and rsa keys succeeded
21:22:33 Checking if time adjustment is needed
21:22:33 Local time sync needed. Adjusted: -3
21:22:33 Verifying server fingerprint
21:22:33 Server key fingerprint is valid
21:22:33 Preparing sign in challenge
21:22:33 There was an error during encryptSignMessageArmored
21:22:33 Error during preparing challenge - incorrect passphrase
21:23:33 [Session] App went background
21:23:33 [Session] Scheduling passphrase cache clear
21:23:33 [Session] Passphrase cache cleared
21:30:29 File logging tree planted
21:30:30 Checking biometry state
21:30:35 Checking biometry state
I get an error when trying to link Passbolt to the mobile app. My request on GitHub was closed and sent here.
passbolt gps healthcheck - good. Not error.
What could be the error?
Thanks
Hello @lowdog136,
looks like an error during sign-in challange preparation in the Crypto.newKeyFromArmored(serverPublicKey) stating about server public key that the key contains too many entities. Possibly the server key was re-generated during restarts and both old and new keys ended up in the keydata response.
Can you run the healthcheck and provide output?
Cheers
hello, mmichalek
[INFO] Linux 31b5281db6df 6.8.0-85-generic #85-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep 18 15:26:59 UTC 2025 x86_64 GNU/Linux
[PASS] PHP version 8.4.16.
[INFO] gpg (GnuPG) 2.4.7 / libgcrypt 1.11.0
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/lib/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/lib/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/lib/passbolt/tmp/ -type f)
[HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://pass.fishlab.su
SMTP settings
[HELP] You can try:
[FAIL] Could not connect to passbolt repository to check versions. It is not possible to check if your version is up-to-date.
[INFO] The self registration provider is: Email domain safe list.
[PASS] 35 tables found.
[PASS] The database version is supported.
Metadata
[FAIL] 4 error(s) found. Hang in there!
Hi @lowdog136
could you please resolve the first 2 fails from the healthcheck? Usually it helps, like in this topic: https://community.passbolt.com/t/ios-android-app-http-forbidden/13570/6.
There are also some changes in 5.10.0-1-ce related to JWT management, but this is a long shot.
G’day @lowdog136,
Following on from @grzegorz, once you’ve resolved those healthcheck FAILs, it’s worth also investigating the key entity issue directly, since that’s what the mobile log is pointing at.
The error gopenpgp: the key contains too many entities means the server key returned by /auth/verify.json contains more than one PGP key block. The mobile gopenpgp library expects exactly one and fails at the newKeyFromArmored call. This can happen if the server GPG key was regenerated across container restarts and the old key wasn’t cleaned out of the keyring.
You can check what the endpoint is actually returning:
bash
curl -sk https://pass.<yourdomain>/auth/verify.json | python3 -m json.tool | grep -c "BEGIN PGP PUBLIC KEY"
If that returns more than 1, inspect the keyring inside the container:
bash
docker exec -it <container> bash
gpg --homedir /var/lib/passbolt/.gnupg --list-keys
If multiple keys are present, you’ll need to export only the one matching the fingerprint in your config, replace the key file, and restart.
Cheers
Gareth
