“Oops, something went wrong” when trying to set up Mobile Transfers
When trying to setup the mobile access from the WebGUI I’ve got an error:
And also this error:
`No data available.Message
crypto.subtle is undefined
Stack
86184/getTransferHash/<@moz-extension://ae164250-1211-4d07-b65e-e60c32e1912e/data/js/dist/app.js:2:275570
getTransferHash@moz-extension://ae164250-1211-4d07-b65e-e60c32e1912e/data/js/dist/app.js:2:275697
createTransfer@moz-extension://ae164250-1211-4d07-b65e-e60c32e1912e/data/js/dist/app.js:2:277040
I’d look on the forums and I’m not able to find anything about this issue.
Can you please help?
Thanks-you!
Guillaume
Hi @guillaumesoucy are you using a self-signed cert? If so, this page regarding importing certs may help.
Hello garrett,
I’m currently not using any certificate at all for now but, I will do later on for sure. I’m just running out time.
It is possible to make it work without any certificate?
Thank-you,
Guillaume
Mobile use requires https. What ports does the mobile app use during setup? - #2 by remy
Okay, I’d make the changes and it work, I’m now able to connect with my iPhone. Will make those changes permanently later on. I’m happy that it could finally work. :wink:
Thanks,
Guillaume
