Passbolt a virtual machine backup
When you restore your original Passbolt VM on a separate VMware host with different IP and URL (because you cannot use the same URL for 2 different servers) and you access the new Passbolt, you are asked for recovery to configure the plugin in a browser.
After requesting the recovery you are prompted to import your existing key of your account.
However it says: This key doesn’t match any account.
What could be the problem?
How to best run 2 instances of passbolt with same account?
Thank you
Hi, please disregard this topic and please delete it. I was playing around and the the recovery works. I just added a wrong private key.
So when you recover Passbolt with a new URL and IP but the same database it will work.
Cheers
