Passbolt desktop application on Windows does not do anything when I click on URL, or Click Open URI in new tab.
G’day Pritam.
Which version of the passbolt windows app are you using?
https://github.com/passbolt/passbolt-windows/releases
Does it install ok from the desktop account kit you downloaded from your user profile in the browser?
Cheers
Gareth
I am using 2.5.0.0 but from Windows store, not from the Passbolt site.
Installs everything fine from Microsoft store application and password are synched. The links do not open or do anything when I click directly or open URI in new tab it does not do anything.
Anyone has the same problem/solution?
I redeployed the application in docker. and just added single password entry from web extension portal. The same things happens in Desktop application. The entry shows but nothing happens if I click the URL. The URL is proper https://www.github.com also tried with https://github.com. Same issue.
Any update? Any one having this issue ? Its a blocker for us. Please help or vote +1 if you are facing the same issue.
Hi Pritam.
I confirm that URI in resources are highlighted like a clickable link but no action is taken when they are clicked, nor is there a ‘copy’ button next to them, or other way to launch the URI.
I think it might be task (PB-37654) but I’ll discuss it with the team and get back to you.
Sorry it’s taken so long to confirm this.
Cheers
Gareth
