Passbolt is offline for half an hour.
My table directory_reports_items is 12GB with ~ 500000 Entries. This makes 95% of the entire Database. I dont know why this is.
Q2 - Who is impacted?
Every one with LDAP Sync.
Db Backups tooks minutes, in a daily basis they lock each other. For example
we are using a central database. Backups took place between 4 - 5. But the Backup waits for table locks. Sometimes it will need to wait to 8 o’clock. Passbolt seems to be constantly doing work but no one is using from 4 to 5. So Passbolt seems do do something by his own.
implement something like directory_reports_items_purge.
implement something like a maintanace mode.
