Passbolt does not show newly created passwords
Yesterday I discovered, that my self hosted CE Docker passbolt does not show new passwords any more anywhere. Not on web, not on browser plugin. When I create password, passbolt says new password created successfully and it shows up in passbolt web page but when I refresh page, it is lost. Same with updating. When I update some old password user name it says update is successful, it shows new username field and modification date and after refresh it still shows old username and modified date is in far past. At the same time data in the database is changed correctly in both update and also in case of adding new passwords. The passbolt is behind proxy. I have restarted passbolt, cleared proxy cache, restarted proxy. I am missing something obvious. Seems to be interesting case?
Hello @raido ,
Welcome to our community :smile:
Have you made any changes before this behaviour? (updating the browser, updating passbolt …) typically I want to know what happened between the time it was working and when you noticed this issue.
Could you share the output of the status-report with us? If you are running docker as root it will be:
su -s /bin/bash -c "/usr/share/php/passbolt/bin/status-report"
Also, which browser are you using?
Thank you for prompt feedback. I have changed firefox from snap version to “normal, no-snap” version and back and have messed with it to get back ma history, plugins and also Passbolt plugin, so certainly this may be the source of my trouble. Passbolt server side has not been changed.
Is it ok to run provided command as www-data user? Docker runs as root, but nginx user is www-data. Here is the result:
www-data@d7922ac5f9ae:/usr/share/php/passbolt$ /usr/share/php/passbolt/bin/status-report
/ _
//./_//__/
Passbolt CE 4.1.1
Cakephp 4.4.14
Linux d7922ac5f9ae 5.10.0-21-amd64 #1 SMP Debian 5.10.162-1 (2023-01-21) x86_64 GNU/Linux
PHP 8.2.7 (cli) (built: Jun 9 2023 19:37:27) (NTS)
ERROR: /usr/share/php/passbolt/bin/utils.sh: line 64: mysql: command not found
gpg (GnuPG) 2.2.40
libgcrypt 1.10.1
/ _
//./_//__/
[PASS] PHP version 8.2.7.
[PASS] Full base url is set to https://passbolt.local
[HELP] cURL Error (6) Could not resolve host: passbolt.local
[PASS] 36 tables found
[PASS] Using latest passbolt version (4.1.1).
SMTP Settings
[FAIL] 4 error(s) found. Hang in there!
/ _
//./_//__/
Cleanup shell (dry-run)
1 issues found in table Passbolt/Folders.FoldersRelations (missing resources folders relations)
1 issues detected, please re-run without --dry-run to fix.
/ _
//./_//__/
Data check shell
[PASS] Can validate: 764/764
[PASS] Can validate: 1/1
[PASS] Can validate: 0/0
[PASS] Can encrypt: 2/2
[PASS] Pass validation service checks: 2/2
[PASS] Entity data and armored key data matches: 2/2
[PASS] Is not expired: 2/2
[PASS] Is armored key format valid: 2/2
[PASS] Can validate: 2/2
[PASS] Can validate: 4/4
[PASS] Can validate: 116/116
[PASS] Can validate: 150/150
I guess web certificate errors are ok, as I run passbolt behind proxy which offloads also ssl.
I am using Firefox 114.0.2. Snap for Ubuntu
PS quite strange, that I can use old passwords without problems, just can not see new ones stored in database.
Tahnk you for everyone. I got my passbolt working again. The problem was indeed in Firefox. I cleared Firefox cookies, site data and cache and suddenly all my passwords and modifications appeared.
Raido
