Passbolt is freezing after login
[x ] I have read intro post
Let me start by saying I have 2 networks, one which is connected to the internet and one which is not. My plan is to install and configure the passbolt on the network which is connected to the internet and then transfer it to the internal network. I’m using ubuntu server 20.04 on vCenter. I have used the instruction regarding 20.04 install passbolt and all the features work after the installation.
But after transferring the vm to the internal network, and reconfiguring the passbolt.php, as soon as I login to the server, I can only see the background and passbolt logo but non of the options and tabs available. I can logout with the firefox browser extension and when I login its the same issue.
I have tried cake passbolt cleanup, cache clean_all, passbolt install --force and after the new installation I have configured my user again but still the same issue after login into the server.
Healthcheck says everything is looking good. I would appreciate any advice as I have been stuck on this for couple of days.
/var/log/passbolt/error.log is producing error logs when ever I try to login with chrome but when I login with firefox I dont see any log and in both instance the UI freezes after login.
2021-06-08 13:08:32 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Passbolt version
Passbolt CE 3.2.1
Cakephp 4.2.4
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://10.105.1.17
[HELP] fopen(): Peer certificate CN=Sohrab Nz' did not match expected CN=10.105.1.17’
fopen(https://10.105.1.17/healthcheck/status.json): failed to open stream: operation failed
[PASS] 25 tables found
[FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
This is what my UI looks like after login!
Please close as I was using chrome version 66 and passbolt requires chrome 79=>
