Passbolt on ubuntu 22 installation issues
I am trying to install CE on Ubuntu 22.04.5 LTS for POC and getting the below error, followed the steps out lined in troubleshooting with no luck. please help.
$ sha512sum -c passbolt-ce-SHA512SUM.txt && sudo bash ./passbolt-repo-setup.ce.sh || echo “Bad checksum. Aborting” && rm -f passbolt-repo-setup.ce.sh
sha512sum: passbolt-repo-setup.ce.sh: No such file or directory
passbolt-repo-setup.ce.sh: FAILED open or read
sha512sum: WARNING: 1 listed file could not be read
Thanks,
Sridhar
Hello @chvgms,
Welcome to the community :slight_smile:
It looks like when you ran the shasum the file was not there, which caused the error:
Also, we removed the support for Ubuntu 22.04 with passbolt v5 as minimum requirements are now php 8.2, (by default on Ubuntu 22.04 its PHP 8.1)
So I would recommend installing Passbolt on Ubuntu 2404 and ensure that the dep script is present before running the shasum check.
thx for the response.
