Hi
I did follow that manual:
https://www.passbolt.com/docs/hosting/install/ce/oraclelinux/
I have no let’s exncrypte certs, I did install a wildcard certificate that is valid and not expired.
After installing, Passbolt is working fine. Health Check says:
After a wile of minutes, the server is not longer reachable.
Now the healthcheck says
and in the browers that error:
Something went wrong!
The operation failed with the following error:
Could not verify the server key. The authentication failed.
When i reboot the system, passbolt works fine again for some minutes. then the same issue.
