I want to use self-signed SSL certificates and followed the SSL configuration tutoral on this page: https://help.passbolt.com/configure/https/ce/debian/manual.html
For some reason it doesn’t work properly and gives me 3 errors, you can see in the health check below.
I already changed my full base URL in /etc/passbolt/passbolt.php
and tried to configure nginx manually by adding the following lines to /etc/nginx/sites-available/nginx-passbolt.conf
server {
listen 8080 ssl;
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
Furthermore I updated my openssl to the latest version.
I’d be very grateful if you could help me because I don’t know anymore how to fix the issue.
Regards
Justin
Health check log
[PASS] PHP version 7.3.31-1~deb10u1.
[PASS] Full base url is set to https://192.168.10.34:8080
error:1408F10B:SSL routines:ssl3_get_record:wrong version number
fopen(https://192.168.10.34:8080/healthcheck/status.json): failed to open stream: operation failed
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.4.0).
My system
System: Raspberry Pi 4
OS: Raspbian 10
Web Server: Nginx 1.14.2
PHP v.: 7.3.31-1~deb10u1
Passbolt v.: 3.4.0
