I never get to the screen asking to setup my first user with a password.
This is my health check.
dahoward@raspberrypi:~ $ sudo /usr/share/php/passbolt/bin/status-report
// _,///./_//__/
Passbolt CE 4.1.1
Cakephp 4.4.14
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
PHP 7.4.33 (cli) (built: Jun 9 2023 16:51:37) ( NTS )
mysql Ver 15.1 Distrib 10.5.19-MariaDB, for debian-linux-gnueabihf (armv7l) using EditLine wrapper
gpg (GnuPG) 2.2.27
libgcrypt 1.8.8
// _,///./_//__/
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to https://passbolt.howardslife.net
[PASS] 32 tables found
[PASS] Using latest passbolt version (4.1.1).
SMTP Settings
// _,///./_//__/
Cleanup shell (dry-run)
2023-07-25 03:59:28 notice: Trying to get property āidā of non-object
notice: 8 :: Trying to get property āidā of non-object on line 339 of /usr/share/php/passbolt/plugins/PassboltCe/Folders/src/Model/Table/FoldersRelationsTable.php
// _,///./_//__/
Data check shell
[PASS] Can validate: 2/2
[PASS] Can validate: 0/0
[PASS] Can encrypt: 0/0
[PASS] Pass validation service checks: 0/0
[PASS] Entity data and armored key data matches: 0/0
[PASS] Is not expired: 0/0
[PASS] Is armored key format valid: 0/0
[PASS] Can validate: 1/1
2023-07-25 03:17:15 warning: file_get_contents(/etc/passbolt/gpg/serverkey.asc): failed to open stream: No such file or directory
Request URL: /install/system_check
Referer URL: https://passbolt.howardslife.net/install
Client IP: 192.168.1.1
2023-07-25 03:17:15 warning: file_get_contents(/etc/passbolt/gpg/serverkey_private.asc) [<a href='https://secure.php.net/function.file-get-contents'>function.file-get-contents</a>]: failed to open stream: No such file or directory
Referer URL: *https://passbolt.howardslife.net/install*
2023-07-25 03:21:14 warning: chmod(): Operation not permitted
Request URL: /install/installation/do_install.json
Referer URL: *https://passbolt.howardslife.net/install/installation*
2023-07-25 03:21:14 warning: chmod() [<a href='https://secure.php.net/function.chmod'>function.chmod</a>]: Operation not permitted
2023-07-25 03:42:43 error: [Cake\Routing\Exception\MissingRouteException] A route matching ā/installā could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
2023-07-25 03:46:41 error: [Cake\Routing\Exception\MissingRouteException] A route matching ā/https://passbolt.howardslife.net/ā could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: */https://passbolt.howardslife.net/*
Client IP: 154.28.229.189
2023-07-25 03:58:22 error: [Cake\Routing\Exception\MissingRouteException] A route matching ā/installā could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
