Passbolt website won't start after restart
I have read intro post:
I’m running an arm machine on OCI free tier, ubuntu 22.04. I have no domain with this site, and before the restart the webserver was working fine with just the ip. Attempting to run healthcheck with the command sudo -H -u nginx bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck" gives me the error
sudo: unknown user nginx
sudo: error initializing audit plugin sudoers_audit
Running sudo su -s /bin/bash -c "./bin/cake passbolt healthcheck" www-data gives me: bash: line 1: ./bin/cake: Permission denied and finally, running sudo /usr/share/php/passbolt/bin/status-report gives me
Passbolt CE 4.1.0
Cakephp 4.4.14
Linux virtual-machine2 5.15.0-1038-oracle #44-Ubuntu SMP Thu Jun 22 03:34:10 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
PHP 8.1.2-1ubuntu2.13 (cli) (built: Jun 28 2023 14:01:49) (NTS)
mysql  Ver 8.0.33-0ubuntu0.22.04.2 for Linux on aarch64 ((Ubuntu))
gpg (GnuPG) 2.2.27
libgcrypt 1.9.4
 [PASS] PHP version 8.1.2-1ubuntu2.13.
 [PASS] Full base url is set to
 [FAIL] App.fullBaseUrl does not validate. .
 [HELP] Edit App.fullBaseUrl in /etc/passbolt/passbolt.php
 [HELP] Select a valid domain name as defined by section 2.3.1 of <ietf domain rules link>
 [HELP] Check <troubleshoot ssl link here - I can only have 2 links>
 [HELP] The source URI string appears to be malformed
 [PASS] 32 tables found
 [HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
 [PASS] Using latest passbolt version (4.1.0).
 [HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
 SMTP Settings
 [FAIL] 7 error(s) found. Hang in there!
 Cleanup shell (dry-run)
Data check shell
  [PASS] Can validate: 7/7
  [PASS] Can validate: 0/0
  [PASS] Can encrypt: 1/1
  [PASS] Pass validation service checks: 1/1
  [PASS] Entity data and armored key data matches: 1/1
  [PASS] Is not expired: 1/1
  [PASS] Is armored key format valid: 1/1
  [PASS] Can validate: 1/1
  [PASS] Can validate: 123/123
  [PASS] Can validate: 119/119
2023-07-07 00:18:57 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/goform/formJsonAjaxReq" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /goform/formJsonAjaxReq
Referer URL: http://141.147.104.169:80/login.asp
Client IP: 45.88.90.145
2023-07-07 01:06:33 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/Autodiscover/Autodiscover.xml" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /Autodiscover/Autodiscover.xml
Client IP: 213.109.202.66
2023-07-07 02:35:39 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/solr/admin/info/system" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /solr/admin/info/system?wt=json
2023-07-07 03:00:33 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/.git/config" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /.git/config
Client IP: 194.9.172.238
2023-07-07 03:13:22 error: [Cake\Routing\Exception\MissingRouteException] A route matching "s=/Index/\think\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP21" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: s=/Index/%5Cthink%5Capp/invokefunction&function=call_user_func_array&vars%5B0%5D=md5&vars%5B1%5D%5B%5D=HelloThinkPHP21?s=/Index/%5Cthink%5Capp/invokefunction&function=call_user_func_array&vars%5B0%5D=md5&vars%5B1%5D%5B%5D=HelloThinkPHP21
2023-07-07 03:19:47 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP: 86.15.85.158
2023-07-07 04:47:50 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/geoserver/web/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /geoserver/web/
Client IP: 216.218.206.66
2023-07-07 05:32:02 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/.env" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /.env
Client IP: 146.70.15.20
2023-07-07 05:32:03 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /
2023-07-07 05:41:26 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/console/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /console/
2023-07-07 05:57:55 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/.env" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /.env
Client IP: 109.237.98.226
2023-07-07 06:32:48 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/_ignition/execute-solution" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /_ignition/execute-solution
2023-07-07 06:39:33 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/files/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /files/
Client IP: 159.65.54.222
2023-07-07 09:01:50 error: [Cake\Routing\Exception\MissingRouteException] A route matching "lang=en" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: lang=en?lang=en
Client IP: 8.210.238.183
2023-07-07 12:23:56 error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /usr/share/php/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
2023-07-07 12:24:49 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/client/get_targets" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /client/get_targets
Client IP: 68.183.67.172
2023-07-07 12:24:50 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/geoip/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /geoip/
2023-07-07 12:24:50 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/bundle.js" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Request URL: /bundle.js
2023-07-07 12:24:50 error: [Cake\Routing\Exception\MissingRouteException] A route matching "/files/" could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 197
Running nmap localhost shows that there are ports open
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-07 15:00 UTC
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000097s latency).
Not shown: 996 closed ports
PORT     STATE SERVICE
22/tcp   open  ssh
80/tcp   open  http
111/tcp  open  rpcbind
3306/tcp open  mysql
Nmap done: 1 IP address (1 host up) scanned in 0.04 seconds
Hello and welcome to the forum @ShadowFox88 !
I see in the logs the following error
Do you have composer installed somehow and available globally in your system?
I haven’t installed it separately, if it was installed by the install script then it should be there - running composer tells me that
Command 'composer' not found, but can be installed with:
sudo apt install composer
What do you see now when you reach the IP address ? A blank page ? A 502 error ?
I assume you installed passbolt with the package so the composer message is a false positive.
Do you have both apache2 and nginx installed ?
sudo systemctl status nginx
sudo systemctl status apache2
Best regards,
nginx is working, but the apache2 service cannot be found. Upon trying to connect to the IP, I get the error message that the server took too long to respond - screenshotted below.
You have a firewall issue. From what I can see from my PC on your IP, only port 22/TCP is open:
And the ERR_CONNECTION_TIMED_OUT is typically a blocking firewall issue:
Thank you for telling me, it seems that iptables had reset rules after the restart.
