Passwords offline mode question
Can you tell me if there is a local password sync on my PC? If so, how long before a clear cache ? Can I change this timer?
Best Regard,
Loïc
Hi @lcollin Welcome to the forum!
Your question is a bit hard to understand. Can you explain more?
Are you asking about a logout timer in your browser?
Or, how often does the extension sync with the server? (the answer to this is immediately upon login or any adding or changing of a password)
Thank you for your answer.
I will try to present you my problem differently:
We want to use passbolt to manage our common passwords on our local network. We don’t want to open the tool on the outside (WAN).
So, when we are on the move, we would like to know how long the data are kept in the browser extension, or on the mobile app without having to reconnect on our LAN.
If I go on vacation for 2 weeks, without my extensions being connected to my LAN, will the password filling functions still be available?
Hey @lcollin,
We do not have a offline mode, it is something that we are considering, but at the moment you need to download the secret (you encrypted version of the password) from the server to consume it. So a network connection to the server is mandatory.
Max
Hi @max ,
Deviating a bit from dedicated offline mode, is the Keepass sync from roadmap in any active discussion or completely on back burner?
We use Keepass and are trialing Passbolt to be our main password repository. Keepass would still be used for non-browser systems etc. Having sync between Passbolt and Keepass would give us the offline capability we need when in remote sites without active network connection.
Definitely on the roadmap, where we will most likely add the UUID to each resource in the KeePass file.
The issue arises when you have only read-only access and need to resync a KeePass file with updated resources.
In any case, TL;DR: Yes, it is on the roadmap because we know that most of our users are former or current KeePass users.
Stay tuned.
This is also important to our team. This feature will allow us to move from bitwarden
I would like to know the current status of this feature.
We have the requirement to have offline access at least on some password entries in case of a deseaster recovery where also the container with the passbolt database is down.
I read that there is the idea to keep some encrypted password data “cached” in the browser extension. What is the current discussion on this at the end of 2023?
Now that 5.x is in the horizon, will offline mode/Keepass sync be any closer? This is the one major issue we have, needing for example to store network/infra passwords in another system incase the network has issues → server not always reachable… And for on-site work, where there is no network, an offline mode is a must.
The offline function would also be the decisive argument for us to use it productively. It would be great to know if there will be offline availability in version 5.x?
Not at the moment. For now the scope of the 5 series (as in 5.0, 5.1, etc.) is encrypted metadata, an updated default content types (icons, multiple urls, autofill helpers), new content types (notes, attachment, passkeys), better on-boarding.
hi, i am voting for offline access too. is crucial for disaster recovery. thanks
Hi, I wait the offline mode to migrate to your solution. it’s no possible if this mode is not exist. It is essential to think a distaster context. How to access your password vault when it is inaccessible. Your solution is very exiting and interresting, that’s all I need!
Thank you.
Same, i upvote this requested feature for disaster or when users are at customer and need to access secret.
Prereq. before consider migration.
For me, the sticking point is also the offline mode. I don’t care whether that comes with the app or with Keepass. I think if it comes with Keepass, many users will switch.
Best regards, Stefan Rutzinger
I want to upvote too, it’s for me an important feature to have.
+1 for offline mode. This is the only thing keeping us to switch to Passbolt.
Thanks!
Here you find the forum post for that feature, including an option to vote for it:
Offline access to password database
