Posix_getuid() error
i followed the installation guide step by step.
At step 8, the console shows all the html-code which outputs “An Internal Server Error occured”.
The error.log outputs:
2018-05-29 07:40:07 Error: [Error] Call to undefined function posix_getuid() in /html/passbolt/config/bootstrap.php on line 286
can somebody tell me, what i have to do now? :innocent:
I’m using passbolt_api Version 2.0.7.
I wanted to host this software on mittwald and did everything as descriped in the guide.
Seems you do not have php posix support on your host.
Your best bet is to contact your hosting provider, maybe they use windows which is not supported.
“This extension is not available on Windows platforms.” https://secure.php.net/manual/en/intro.posix.php
