Powershell SecretManagement
Any plans to add an extension to psgallery for microsofts secretmanagement?
Passbolt is conspicuous by its absence in the list of supported vaults.
BR Kasper
Hi Kasper.
I’d not heard about secretmanager.
Is it still actively supported?
https://github.com/powershell/SecretManagement
Do you have information that’s more current than what I’m finding.
Is this the list of supported vault extensions?
https://learn.microsoft.com/en-us/powershell/utility-modules/secretmanagement/overview?view=ps-modules#discovering-and-installing-vault-extensions
KeePass stopped in beta in 2021
https://www.powershellgallery.com/packages/SecretManagement.KeePass/0.9.2
LastPass stopped in 2020
https://www.powershellgallery.com/packages/SecretManagement.LastPass/0.2.1
Azure Keyvault is still putting out current versions
https://www.powershellgallery.com/packages/Az.KeyVault/6.4.2
If I’m pointing to the wrong repo then please forgive me.
Cheers
Gareth
