Private Key is not defined or not readable
[ X ] I have read intro post
[ X ] I have read the tutorials, help and searched for similar issues
[ X ] I provide relevant information about my server (component names and versions, etc.)
[ X ] I provide a copy of my logs and healthcheck
[ X ] I describe the steps I have taken to trouble shoot the problem
[ X ] I describe the steps on how to reproduce the issue
Hello! I’ve been a big fan of Passbolt since implementing it in early 2019. It works great, thank you for making a fantastic product! :grinning:
In preparation for upgrading to 3.0.1, I decided to do a healthcheck to make sure I had a clean “bill of health” before proceeding. I’m encountering one GPG error. Everything else checks out fine other than the obvious “Hey, you should update me” error. It seems a bit strange to me, as the Passbolt installation has been running fantastically for our team of about 60 users without any issues.
System is currently running the following. Let me know if I missed anything relevant. :slight_smile:
  • Ubuntu 18.04.5 LTS
  • mysql Ver 15.1 Distrib 10.1.47-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
  • nginx version: nginx/1.14.0 (Ubuntu)
  • PHP 7.2.24-0ubuntu0.18.04.7 (cli) (built: Oct 7 2020 15:24:25) ( NTS )
    Copyright (c) 1997-2018 The PHP Group
    Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
    with Zend OPcache v7.2.24-0ubuntu0.18.04.7, Copyright (c) 1999-2018, by Zend Technologies
Healthcheck results:
[PASS] PHP version 7.2.24-0ubuntu0.18.04.7.
[PASS] Full base url is set to https://[redacted]
[PASS] 26 tables found
[FAIL] The private key file is not defined in config/passbolt.php or not readable.
[HELP] Ensure the private key file is defined by the variable passbolt.gpg.serverKey.private in config/passbolt.php.
[HELP] Ensure there is a private key armored block in the key file.
[HELP] Ensure the private key defined in config/passbolt.php exists and is accessible by the webserver user.
[HELP] See. Passbolt Help | Installation
[FAIL] This installation is not up to date. Currently using 2.13.5 and it should be v3.0.1.
[HELP] See. Passbolt Help | Update
I am confused at how passbolt would even be working if the server couldn’t read its own private key file. Here is the relevant portion of passbolt.php:
'passbolt' => [
    // GPG Configuration.
    'gpg' => [
        // Main server key.
        'serverKey' => [
            'fingerprint' => '[redacted]',
            'public' => CONFIG . DS . 'gpg' . DS . 'serverkey.asc',
            'private' => CONFIG . DS . 'gpg' . DS . 'serverkey_private.asc',
And, www-data seem so to have no problems accessing serverkey_private.asc:
$ sudo -H -u www-data bash -c “cat /var/www/passbolt/config/gpg/serverkey_private.asc”
-----BEGIN PGP PRIVATE KEY BLOCK-----
[redacted]
-----END PGP PRIVATE KEY BLOCK-----
www-data seems to be able to list the key and get the fingerprint properly too:
$ sudo su -s /bin/bash -c “gpg --list-keys” www-data
/home/www-data/.gnupg/pubring.kbx
pub rsa2048 2018-10-26 [SC]
[redacted, but matches key fingerprint in passbolt.php]
uid [ultimate] passbolt <bryan@[redacted].com>
sub rsa2048 2018-10-26 [E]
[all the user keys here, but redacted]
Any ideas what to troubleshoot next?
Many thanks for any and all assistance. :slight_smile:
Hello @brywhi,
Can you confirm you are also running the healthcheck as www-data?
This checks currently encompass three items in the code:
$checks['gpg']['gpgKeyPrivate'] = (Configure::read('passbolt.gpg.serverKey.private') !== null);
$checks['gpg']['gpgKeyPrivateReadable'] = is_readable(Configure::read('passbolt.gpg.serverKey.private'));
if ($checks['gpg']['gpgKeyPrivateReadable']) {
    $privateKeydata = file_get_contents(Configure::read('passbolt.gpg.serverKey.private'));
    $blockStart = '-----BEGIN PGP PRIVATE KEY BLOCK-----';
     $checks['gpg']['gpgKeyPrivateBlock'] = (strpos($privateKeydata, $blockStart) === 0);
Most likely this is the “is_readable” that is failing (can you show us the permissions on this file?), or the check for the block start (maybe there is a \n at the start?).
Haha, you are a genius @Remy! I just had a new line at the start of serverkey_private.asc. :rofl:
Got rid of it via nano, and now all is well.
For future readers (if any) of this thread, I just did cat -v serverkey_private.asc to see non-printable characters, and removed them from the start of the file with nano.
Many thanks for your help, @Remy! I will be testing the upgrade path next.
@brywhi as a heads up if you want to stay on Ubuntu 18, you will need to upgrade to php7.3. It’s probably best in my opinion to go for a Ubuntu 20.
Thanks! Yeah, I am planning on moving to 20.04- we have several other boxes in our environment running it. Thanks again for all your help.
