Problem activating SSO plugin
Good morning, I tried to activate the alpha plugin released on the new version and the option doesn’t shows in the Administration page.
I followed the steps in this guide in order to activate the Microsoft SSO and test it.
I have the browser extension v3.9.1 and Passbolt PRO v3.9.0., using Apache v2.4.38, PHP v8.2.1 and Debian 10.
Here is the passbolt.php file with the flag activated:
<?php
 * Passbolt ~ Open source password manager for teams
 * Copyright (c) Passbolt SA (https://www.passbolt.com)
 * Licensed under GNU Affero General Public License version 3 of the or any later version.
 * For full copyright and license information, please see the LICENSE.txt
 * Redistributions of files must retain the above copyright notice.
 * @copyright     Copyright (c) Passbolt SA (https://www.passbolt.com)
 * @license       https://opensource.org/licenses/AGPL-3.0 AGPL License
 * @link          https://www.passbolt.com Passbolt(tm)
 * @since         2.0.0
 * PASSBOLT CONFIGURATION FILE
 * This is a generated configuration file, which was generated by the passbolt web installer.
 * To see all available options, you can refer to the default.php file, or replace this file
 * by a copy of passbolt.default.php
 * Do not modify default.php or you may break your upgrade process.
 * Read more about how to install passbolt: https://www.passbolt.com/help/tech/install
 * Any issue, check out our FAQ: https://www.passbolt.com/faq
 * An installation issue? Ask for help to the community: https://community.passbolt.com/
return [
    'App' => [
        'fullBaseUrl' => '$url',
    // Database configuration.
    'Datasources' => [
        'default' => [
            'host' => 'localhost',
            'port' => '3306',
            'username' => '$username',
            'password' => '$pass',
            'database' => '$db',
    // Email configuration.
    'EmailTransport' => [
        'default' => [
            'host' => '$host',
            'port' => 25,
            'username' => '$username,
            'tls' => null,
            //'timeout' => 30,
            'client' => '$server',
            //'url' => null,
    'Email' => [
        'default' => [
            'from' => [$email' => 'Passbolt'],
            //'charset' => 'utf-8',
            //'headerCharset' => 'utf-8',
    'passbolt' => [
        // GPG Configuration.
        'gpg' => [
            // Main server key.
            'serverKey' => [
                'fingerprint' => '$server_key',
                'public' => CONFIG . DS . 'gpg' . DS . 'serverkey.asc',
                'private' => CONFIG . DS . 'gpg' . DS . 'serverkey_private.asc',
        'registration' => [
            'public' => false,
        'ssl' => [
            'force' => true,
        'security' => [
                'smtpSettings' => [
                        'endpointsDisabled' => true,
        'email' => [
                'validate' => [
                        'mx' => true,
        'sso' => [
                'enabled' => true
Here is the Administration page:
And here you are the healthcheck command:
Passbolt commands should only be executed as the web server user.
The command should be executed with the same user as your web server. By instance:
su -s /bin/bash -c "$folder/bin/cake COMMAND" HTTP_USER
where HTTP_USER match your web server user: www-data, nginx, apache, http
 [PASS] PHP version 8.2.1.
 [PASS] Full base url is set to $link
 [PASS] 46 tables found
 [PASS] The environment variable GNUPGHOME is set to $folder/.gnupg.
 [PASS] The directory $folder/.gnupg containing the keyring is writable by the webserver user.
 [PASS] The public key file is defined in $folder/config/passbolt.php and readable.
 [PASS] The private key file is defined in $folder/passbolt.php and readable.
 [PASS] The server key fingerprint matches the one defined in $folder/config/passbolt.php.
 [PASS] The server public key defined in the $folder/config/passbolt.php (or environment variables) is in the keyring.
 [PASS] Using latest passbolt version (3.9.0).
 [PASS] The $folder/config/jwt/ directory is not writable.
 SMTP Settings
 [PASS] The SMTP Settings plugin endpoints are disabled.
Can you help me to activate it in order to test it?
Thank you
Sorry there is a mistake in the doc, it should be
        'plugins' => [
            'sso' => [
                'enabled' => true
Fixing the doc right now.
Hello @remy, that plugins section is inside passbolt section or out of it?
   'passbolt' => [
        'gpg' => [
            // Main server key.
            'serverKey' => [
                'fingerprint' => '$key',
        'registration' => [
            'public' => false,
        'ssl' => [
            'force' => true,
        'security' => [
                'smtpSettings' => [
        'email' => [
                'validate' => [
                        'mx' => true,
        'plugins' => [
                'sso' => [
                        'enabled' => true,
It should be inside the passbolt section.
That worked, thank you for quick helping
Enjoy! Looking forward your feedback! :slight_smile:
Hello again, I followed up the steps through Azure AD and when I try to log-in to save the data, it shows this message to me:
I tried with other signInAudience values, like PersonalMicrosoftAccount, and sometimes it shows another error:
Do you know why I can’t set it up?
The first message indicates that the email is not part of the access token what is returned by Azure AD. It should be part of the default claims or the email cannot be validated by passbolt.
The second message indicates that the code is not returned by Azure AD, most likely because it’s returning an Error instead, because of the configuration.
Can you confirm you have:
  • Email set in the user record in Azure AD
  • The same email in Azure AD and in Passbolt username
Did you follow the same procedure described in the help site to configure Azure AD, did you set some additional options? Maybe the email claim is not included in your configuration?
You can reach out to me at contact@passbolt.com, maybe we can do a quick call to get to the bottom of this.
I followed the steps in the guide quite closely and just changed the supported account type, but then I checked with the same mentioned, which gave me the same error.
The account I’m using on Azure AD and Passbolt have the same email, and I think it is correctly set-up in the user record, but it is my first time with Azure AD so maybe I did something wrong.
Also, I tried to add email as an optional claim at the app but still not working.
I’m going to write you to the provided email to see what is happening
What do you see under the “API permissions”? Maybe it’s configured to have different default?
This is what I have:
Ok we had a call with @Termindiego25 and we saw the “email” was not specified for the user:
Screenshot 2023-01-24 at 15.19.58
Yep, the user created by default when I created the tenant had this field blank, so you have to check that have the same email as your Passbolt account in order to work properly.
Thank you again @remy for your quick helping!
