I’ve installed Passbolt on CentOS 7.x without any issues and I would like to find out whether it’s OK to perform regular OS patching, or it’s always important to update both OS and Passbolt software itself.
Thank you
Hello @radan,
Regular OS patching should not be an issue. But do a backup of your data just in case.
In the case the version of PHP is upgraded, which would be surprising for a patching update.
- The php-gnupg extension would require to be recompiled (sudo pecl install gnupg)
- The composer dependencies could also be impacted, better to reinstall them
composer install --no-dev(from the passbolt folder).
I don’t think SELinux could be an issue.
Hope that it will help,
Best regards.
It looks like these are just minor patch updates which should be fine (based on your reply)?
—> Package nginx.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-all-modules.noarch 1:1.12.2-2.el7 will be updated
—> Package nginx-all-modules.noarch 1:1.12.2-3.el7 will be an update
—> Package nginx-filesystem.noarch 1:1.12.2-2.el7 will be updated
—> Package nginx-filesystem.noarch 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-http-geoip.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-http-geoip.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-http-image-filter.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-http-image-filter.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-http-perl.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-http-perl.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-http-xslt-filter.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-http-xslt-filter.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-mail.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-mail.x86_64 1:1.12.2-3.el7 will be an update
—> Package nginx-mod-stream.x86_64 1:1.12.2-2.el7 will be updated
—> Package nginx-mod-stream.x86_64 1:1.12.2-3.el7 will be an update
—> Package php-cli.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-cli.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-common.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-common.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-devel.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-devel.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-fpm.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-fpm.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-gd.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-gd.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-intl.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-intl.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-json.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-json.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-ldap.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-ldap.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-mbstring.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-mbstring.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-mysqlnd.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-mysqlnd.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-pdo.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-pdo.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-pear.noarch 1:1.10.9-2.el7.remi will be updated
—> Package php-pear.noarch 1:1.10.9-3.el7.remi will be an update
—> Package php-process.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-process.x86_64 0:7.2.19-2.el7.remi will be an update
—> Package php-xml.x86_64 0:7.2.18-1.el7.remi will be updated
—> Package php-xml.x86_64 0:7.2.19-2.el7.remi will be an update
@radan yes that should be fine
