Repository Issues when hitting apt update
Hi All
I am using the following documentation to migrate from install scripts to ubuntu
I followed the steps from here Passbolt Help | Migrate passbolt CE from install scripts to Ubuntu package
I seem to be getting the following back when running the apt update command
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY DE8B853FC155581D
Has anyone ran into this issue ?
Hi @moedawood inside the help page, there are mirror servers that you can try:
gpg --keyserver hkps://keys.mailvelope.com --recv-keys 0xDE8B853FC155581D
gpg --keyserver hkps://pgp.mit.edu --recv-keys 0xDE8B853FC155581D
gpg --keyserver hkps://keys.gnupg.net --recv-keys 0xDE8B853FC155581D
Max
And by the way, ensure you have correctly followed steps 4, 5 and 6.
If you execute this command:
cat /usr/share/keyrings/passbolt-repository.gpg | gpg
It should return:
gpg: WARNING: no command supplied.  Trying to guess what you mean ...
pub   rsa2048 2020-05-18 [SC] [expires: 2022-05-18]
      3D1A0346C8E1802F774AEF21DE8B853FC155581D
uid           Passbolt SA package signing key <contact@passbolt.com>
sub   rsa2048 2020-05-18 [E] [expires: 2022-05-18]
Hi Max
Thank you for your prompt response
I have tried the following to no avail
I receive the following from the two mirror servers
First one gives me this
gpg: key DE8B853FC155581D: “Passbolt SA package signing key contact@passbolt.com” not changed
gpg: unchanged: 1
When i run apt update again I still receive the same error
Hi
Thank you for the response
I receive the following when running the command above
gpg: WARNING: no command supplied. Trying to guess what you mean …
uid Passbolt SA package signing key contact@passbolt.com
Can you post here your /etc/apt/sources.list.d/passbolt.sources content ? Do you have any other file in /etc/apt/sources.list.d folder ?
Can you share full output of your apt update ?
Are you using Ubuntu 20.04 or 18.04 (cat /etc/os-release) ?
Thanks !
Hi
Types: deb
URIs: https://download.passbolt.com/ce/ubuntu
Suites: focal
Components: stable
Signed-By: /usr/share/keyrings/passbolt-repository.gpg
There are no other files in the folder
Full Output apt update
Ubuntu 18.04.4 LTS
I guess Ubuntu 18.04 is not able to read well new apt list format.
You can try to delete passbolt.sources file:
sudo rm /etc/apt/sources.list.d/passbolt.sources
and create a /etc/apt/sources.list.d/passbolt.list with this content:
deb [signed-by=/usr/share/keyrings/passbolt-repository.gpg] https://download.passbolt.com/ce/ubuntu focal stable
We provide only Ubuntu 20.04 package repository and our package has not been tested on Ubuntu 18.04 so run it at your own risk.
Usually, it is a bad idea to mix Ubuntu 20.04 focal packages with Ubuntu 18.04 packages.
Hi
So I upgraded my server to the latest ubuntu version
See below image, still seem to get the same error
@moedawood If one keyserver hangs, try one of the other two provided.
Hi
The key does get added but when i run apt update I still get the NO PUBKEY ERROR
Hi again @moedawood :wave:
I was able to reproduce your issue, can you check rights of /usr/share/keyrings/passbolt-repository.gpg ?
It must be 644:
$ sudo stat -c %a /usr/share/keyrings/passbolt-repository.gpg
644
$ sudo stat -c %A /usr/share/keyrings/passbolt-repository.gpg
-rw-r--r--
And be owned by root:
$ sudo stat -c %U:%G /usr/share/keyrings/passbolt-repository.gpg
root:root
Some other checks:
$ file /usr/share/keyrings/passbolt-repository.gpg
/usr/share/keyrings/passbolt-repository.gpg: PGP/GPG key public ring (v4) created Mon May 18 14:11:39 2020 RSA (Encrypt or Sign) 2048 bits MPI=0xa827fe9657144e59...
$ gpg --show-keys /usr/share/keyrings/passbolt-repository.gpg
$ grep ^UMASK /etc/login.defs
UMASK           022
Let me know :slight_smile:
Hi
This worked perfectly
Thank you for everyone’s assistance I appreciate it
Thanks for the feedback. You are not the first one who is reporting that, we will update documentation accordingly and add a warning about this.
Have a nice day :sun_with_face:
