SMTP + docker + AWS SES doesn;t work
I installed Passbolt 5.0.0 with Docker on Linux. I’m using SES. The user works externally, but not in Passbolt. The instance ports are open. The credentials are valid externally. Has anyone had this issue? I couldn’t find it. I used username with and without the @domain.com
Email could not be sent: SMTP Error: 530 Authentication required
See trace
[220] ESMTP SimpleEmailService-d-E4NJUWFKC dfkYifDaGe42THICjosV
EHLO passvault.*****
[250] email-smtp.amazonaws.com
[250] 8BITMIME
[250] STARTTLS
[250] AUTH PLAIN LOGIN
[250] Ok
STARTTLS
[220] Ready to start TLS
EHLO passvault.**.com
[250]
[250] 8BITMIME
[250] STARTTLS
[250] Ok
**AUTH PLAIN *******
[535] Authentication Credentials Invalid
Hi, you should use dedicated credentials and not your current one.
https://docs.aws.amazon.com/ses/latest/dg/smtp-credentials.html
You’re probably using standard AWS Access Key ID + Secret Access Key, but Amazon SES SMTP does not accept those directly. It expects a converted SMTP password, derived from your IAM Secret Access Key.
Fix it: How to generate valid SES SMTP credentials
  1. Create an IAM user (or use an existing one) with at least the AmazonSESFullAccess or AmazonSES_SendOnlyAccess policy.
  2. In the IAM Console, go to Security Credentials and create an Access Key for that user.
  3. Convert that access key pair to SMTP credentials using the official AWS tool:
  1. Use the Access Key ID as your SMTP username
    And the converted SMTP password as your SMTP password
Let me know if it helps
Thanks, that works for me.
Iam user is already created with smtp credentials
Hello, I have this Docker Compose, when I restart it or down and up I always have to do the setup again, as well as add the permissions to the keys already generated```
version: ‘3’
image: passbolt/passbolt:latest
- “587:587”
- “443:443”
- “80:80”
- DATABASE_HOST=db
- DATABASE_USER=passbolt
- DATABASE_PASSWORD=passbolt
- DATABASE_NAME=passbolt
- APP_FULL_BASE_URL=https://passvault00000000.com
- EMAIL_TRANSPORT_DEFAULT_HOST=email-smtp.us-east-1.amazonaws.com
- EMAIL_TRANSPORT_DEFAULT_PORT=587
- EMAIL_TRANSPORT_DEFAULT_USERNAME=passvault@
- EMAIL_TRANSPORT_DEFAULT_PASSWORD=passbolt
- passbolt_data:/var/www/passbolt
- passbolt_logs:/var/log/passbolt
command:
“/usr/bin/wait-for.sh”,
“-t”,
“0”,
“db:3306”,
“/docker-entrypoint.sh”,
depends_on:
- db
db:
image: mysql:5.7
- MYSQL_ROOT_PASSWORD=passbolt
- MYSQL_DATABASE=passbolt
- MYSQL_USER=passbolt
- MYSQL_PASSWORD=passbolt
- db_data:/var/lib/mysql
passbolt_data:
passbolt_logs:
db_data:
gpg_volume:
jwt_volume:
Are any errors showing up in the logs?
Is this behaviour similar to this one?
https://community.passbolt.com/t/docker-error-when-restarting-server
