[SOLVED]Stuck during install docker compose gpg
Hi everyone,
First of all, English is not my primary langage, so I’m sorry if i make grammar or vacabulary mistake.
  • Environment: Vcenter 6.7 -> Photon OS with Docker -> PassBolt
I’m trying to install passbolt with the docker compose and instructions from there: https://help.passbolt.com/hosting/install/ce/docker.html
With and without modification I have been encountering the same problem:
The installation is stucks there, I can wait 4 hours that cannot change.
I think it’s a problem of virtualisation between docker, photon Os and the method to create the gpg key? but i’m not sure.
What do you think ?
Thank you.
Edit: rng-tools and haveged are installed.
Edit2: My bad… After a shutdown all is good…
Seems like you are missing some of the requirements in particular to have installed on your host rng-tools or haveged
Hi Diego,
rng-tools and haveged are installed on my Photon Os.
edit:
Ho…
After an shutdown it seem that works…
I didn’t think that was that… Linux is not Windows, so I Don’t remember when I have a problem :cold_sweat:
My bad, verry sorry.
