[Spelling] Updated susccessfully to successfully
Hey there, a quick notification of sorts as the community is visted more then the github. I fixed a spelling issue on the API in case that’s something that is usefull to be fixed. Lemme know if anything needs changed. Thanks!
https://github.com/passbolt/passbolt_api/pull/581
Additionally, there’s also someone else who made a similair fix, I’d recommend checking that one as well.
https://github.com/passbolt/passbolt_api/pull/572
Hello, thank you for your report.
Internal tracking ticket: https://app.clickup.com/t/2593179/PB-51077
We’ll aim to include it in the 5.12 release.
