Sub organisations
Hello, I’m testing the CE version, but we are an organization with multiple sub-organizations. Each sub-organization needs to be completely separate. Is Passbolt designed to handle this type of situation?
G’day FD.
I’m not sure how you posted in the ‘announcements’ tag but to answer your question:
It depends ™ on what you define ‘separate’ as.
Any admin can manage all the settings for the passbolt instance and manage all users for an instance.
If you’re ok having centralised administration then you could create groups to represent the organisational units and then have the group managers able to add/remove users.
Group managers have no admin powers outside of that group however so you still have a centralised admin team needing to perform management of the instance, and of user accounts.
Happy to elaborate further if you have more questions.
Cheers
Gareth
