Syntax error in docker install guide
On this page: https://www.passbolt.com/docs/hosting/install/ce/docker/
Steps 4 and 5 show “docker compose -f” however this syntax is not valid.
It will return error unknown shorthand flag: ‘f’ in -f
Should be hyphenated “docker-compose -f”
Hi qbicdesign,
you are probably using an old version of docker. “docker compose” is the recommended version.
my docker has a shorthand for --file
~ # docker -v
Docker version 28.0.1, build 068a01ea9470df6494cc92d9e64e240805ae47a7
~ # docker compose --help
Usage: docker compose [OPTIONS] COMMAND
-f, --file stringArray Compose configuration files
https://docs.docker.com/compose/releases/migrate/
" What are the differences between Compose V1 and Compose V2?"
Best
Hi qbicdesign,
What txt said is true about the new compose being more tightly interated into docker rather than the old docker-compose which was python based.
I only wanted to mention that it might need a configuration change to enable it, depending on how docker is installed.
On macOS while using the Colima container runtime, docker needs the following added to change from docker-compose to docker compose.
$ cat ~/.docker/config.json
        "auths": {},
        "currentContext": "colima",
        "cliPluginsExtraDirs": [
                "/opt/homebrew/lib/docker/cli-plugins"
I hope that helps
cheers
gareth
