I have passbolt installed on my server and smtp is configured. I am able to send the test emails, but other emails are not coming through whether its a login email or any other.
Health Check command says error about “Passbolt is not configured to force SSL use”. Could it be the reason why emails are not coming through.
I am using Brevo smtp setup
------------------Below is the result of the HealthCheck command-----------------------------------------
// _,///./_//__/
[PASS] PHP version 8.1.2-1ubuntu2.18.
[PASS] Full base url is set to https://access.academyofmusicandarts.org
SMTP settings
[HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in /var/www/passbolt/config/passbolt.php.
[PASS] The /var/www/passbolt/config/jwt/ directory is not writable.
[PASS] The public key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The private key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The server key fingerprint matches the one defined in /var/www/passbolt/config/passbolt.php.
[PASS] The server public key defined in the /var/www/passbolt/config/passbolt.php (or environment variables) is in the keyring.
[PASS] Using latest passbolt version (4.9.0).
[HELP] Set passbolt.ssl.force to true in /var/www/passbolt/config/passbolt.php.
[PASS] The deprecated self registration public setting was not found in /var/www/passbolt/config/passbolt.php.
[HELP] Or set passbolt.email.validate.mx to true in /var/www/passbolt/config/passbolt.php.
[PASS] 31 tables found.
-------------------Result of the show queued email command---------------------------------------------
// _,///./_//__/
List of queued emails:
No records found.
------------------------Result of Database Query for queued email------------------------------------------
mysql> select * from email_queue;
Empty set (0.00 sec)
mysql>
--------------------------------------Result of Cron command-----------------------------------------------------
● cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2024-08-05 10:08:50 UTC; 1 day 21h ago
Docs: man:cron(8)
Main PID: 577 (cron)
Tasks: 1 (limit: 2188)
Memory: 1.5M
CPU: 5min 46.303s
CGroup: /system.slice/cron.service
└─577 /usr/sbin/cron -f -P
Aug 07 07:17:01 ubuntu CRON[58735]: pam_unix(cron:session): session closed for user www-data
Aug 07 07:18:01 ubuntu CRON[58756]: pam_unix(cron:session): session opened for user www-data(uid=33) by (uid=0)
Aug 07 07:18:01 ubuntu CRON[58757]: (www-data) CMD (/var/www/passbolt/bin/cron >> /var/log/passbolt.log)
Aug 07 07:18:02 ubuntu CRON[58756]: pam_unix(cron:session): session closed for user www-data
Aug 07 07:19:01 ubuntu CRON[58776]: pam_unix(cron:session): session opened for user www-data(uid=33) by (uid=0)
Aug 07 07:19:01 ubuntu CRON[58777]: (www-data) CMD (/var/www/passbolt/bin/cron >> /var/log/passbolt.log)
Aug 07 07:19:01 ubuntu CRON[58776]: pam_unix(cron:session): session closed for user www-data
Aug 07 07:20:01 ubuntu CRON[58793]: pam_unix(cron:session): session opened for user www-data(uid=33) by (uid=0)
Aug 07 07:20:01 ubuntu CRON[58794]: (www-data) CMD (/var/www/passbolt/bin/cron >> /var/log/passbolt.log)
Aug 07 07:20:01 ubuntu CRON[58793]: pam_unix(cron:session): session closed for user www-data
I have gone through every possible solution, but nothing seems to work now. Any guidance and help would be appreciated.
Let me know if you need any further details or any kind of logs.
Thanks!!
