Hi
I have trouble with that, could everyone help me?
sudo -su nginx bash -c "./bin/cake passbolt migrate --backup"
== 20230512220600 V410ImproveFoldersRelationsIndexesShareFoldersPerformance: migrating
InvalidArgumentException: The specified index on columns ‘foreign_model’ does not exist in /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/MysqlAdapter.php:726
Stack trace:
#0 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php(942): Phinx\Db\Adapter\MysqlAdapter->getDropIndexByColumnsInstructions()
#1 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/AdapterWrapper.php(477): Phinx\Db\Adapter\PdoAdapter->executeActions()
#2 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/TimedOutputAdapter.php(420): Phinx\Db\Adapter\AdapterWrapper->executeActions()
#3 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/AdapterWrapper.php(477): Phinx\Db\Adapter\TimedOutputAdapter->executeActions()
#4 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Plan/Plan.php(151): Phinx\Db\Adapter\AdapterWrapper->executeActions()
#5 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Table.php(719): Phinx\Db\Plan\Plan->execute()
#6 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Table.php(627): Phinx\Db\Table->executeActions()
#7 /var/www/passbolt/vendor/cakephp/migrations/src/Table.php(152): Phinx\Db\Table->update()
#8 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Db/Table.php(686): Migrations\Table->update()
#9 /var/www/passbolt/config/Migrations/20230512220600_V410ImproveFoldersRelationsIndexesShareFoldersPerformance.php(36): Phinx\Db\Table->save()
#10 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager/Environment.php(111): V410ImproveFoldersRelationsIndexesShareFoldersPerformance->up()
#11 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager.php(388): Phinx\Migration\Manager\Environment->executeMigration()
#12 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Migration/Manager.php(359): Phinx\Migration\Manager->executeMigration()
#13 /var/www/passbolt/vendor/robmorgan/phinx/src/Phinx/Console/Command/Migrate.php(122): Phinx\Migration\Manager->migrate()
#14 /var/www/passbolt/vendor/cakephp/migrations/src/Command/Phinx/CommandTrait.php(37): Phinx\Console\Command\Migrate->execute()
#15 /var/www/passbolt/vendor/cakephp/migrations/src/Command/Phinx/Migrate.php(85): Migrations\Command\Phinx\Migrate->parentExecute()
#16 /var/www/passbolt/vendor/symfony/console/Command/Command.php(298): Migrations\Command\Phinx\Migrate->execute()
#17 /var/www/passbolt/vendor/symfony/console/Application.php(1040): Symfony\Component\Console\Command\Command->run()
#18 /var/www/passbolt/vendor/symfony/console/Application.php(301): Symfony\Component\Console\Application->doRunCommand()
#19 /var/www/passbolt/vendor/symfony/console/Application.php(171): Symfony\Component\Console\Application->doRun()
#20 /var/www/passbolt/vendor/cakephp/migrations/src/Command/MigrationsCommand.php(126): Symfony\Component\Console\Application->run()
#21 /var/www/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(189): Migrations\Command\MigrationsCommand->execute()
#22 /var/www/passbolt/vendor/cakephp/migrations/src/Command/MigrationsCommand.php(198): Cake\Console\BaseCommand->run()
#23 /var/www/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(282): Migrations\Command\MigrationsCommand->run()
#24 /var/www/passbolt/src/Command/DatabaseAwareCommandTrait.php(62): Cake\Console\BaseCommand->executeCommand()
#25 /var/www/passbolt/src/Command/MigrateCommand.php(75): App\Command\MigrateCommand->runMigrationsMigrateCommand()
#26 /var/www/passbolt/vendor/cakephp/cakephp/src/Console/BaseCommand.php(189): App\Command\MigrateCommand->execute()
#27 /var/www/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php(334): Cake\Console\BaseCommand->run()
#28 /var/www/passbolt/vendor/cakephp/cakephp/src/Console/CommandRunner.php(172): Cake\Console\CommandRunner->runCommand()
#29 /var/www/passbolt/bin/cake.php(12): Cake\Console\CommandRunner->run()
#30 {main}
MariaDB [passbolt]> SHOW INDEX FROM folders_relations;
Many thanks and best regards
