TOTP text to long in Swedish translation
I have some issues with the Swedish translation string being to long, which means that the “delete” icon won’t show. I have to go into developer tools in Firefox and shorten it do be able to remove a old TOTP setting. The text is now “TOTP (tidbaserat engångslösenord)”, and just remove the stuff inside () does the trick. This should be changed to just say TOTP instead.
